2nd Gen Non-Engine/Transmission HID headlights
Engine/Transmission (1994 - 1998) valve body & tv cable ? pressures
Engine/Transmission (1998.5 - 2002) fuel use
I have a 98 Dodge CTD with aftermarket sport headlights. The ballasts are Hella's with xenon bulbs. The HID's are wired to the low beams. The high beams are wired to a 9004 bulb. Is this correct? Does it matter which bulb sockets are used for each?
Thanks
Rick
RPalermo,
I believe that is correct. Its not until you get to the high end HID projector headlights that the high beams are are part of the HID projectors.
WD
