I've seen quite a few posts on this; but my question is: What exactly are the thiefs doing when they "Pop" the steering column off and jam that thingy in the keyhole; or mess with the wiring, etc?
Will a hidden starter kill keep it from being "Hot wired or rigged" and started? Help me out here. I'm wanting to put a momentary hidden switch somewhere and tap into the clutch wire so that you have to be holding the momentary switch and the clutch "down" to be able and turn the starter. Does this sound right and secure?
If so, what wire do I tap into (color and location), and how do I wire this thing correctly?
Supplies needed (?):
- momentary switch
- what gauge wire?
- relay (I'm guessing not needed)
- will the switch need a power source (from where)?
Thanks for the help
- momentary switch
- what gauge wire?
Thanks for the help
