2nd Gen Non-Engine/Transmission high beams don't work
Engine/Transmission (1998.5 - 2002) pyro guage getting flakey
2nd Gen Non-Engine/Transmission Lug nuts - custom chrome
I have a major lighting problem. High beams do not come on but my fog lights will not go off. I had to finally remove the bulbs. So all I have is low beam. Anyone ever have this problem?
Ok, First off what year is your truck. Dodge trucks are well know to have headlight switch melt down problems. At one time some replacement switches (I think dealer) came with a pigtail that you had to splice into the origanal wiring. If you run the aftermarket ultra bulbs you may have fried the switch or wire harness to the switch. Pull out the switch to check it out. That maybe why your fog lights won't turn off. To pull the switch out you need to pull off the instrument panel trim bezel to access the switch screws. Be carefull with the bezel cause they get fragile with age.
Dodge trucks are well know to have headlight switch melt down problems.. Pull out the switch to check it out. That maybe why your fog lights won't turn off. To pull the switch out you need to pull off the instrument panel trim bezel to access the switch screws. Be carefull with the bezel cause they get fragile with age.
X2!!!!!! But sometimes the NEW switch can be bad right out of the box...ask me how I know.
