high beams with fog light
110 miles per hour ?
friends of coal decals
on my 99 dodge i ran a jumper wire so i could run my fog lightd on with high beams, i found this tip in a old issue of tdr , does anyone know how to do it with a 2004. 5 HO 4x4 2500 pick up ? please email at -- email address removed -- Oo.
I bought the brite box with fogs lights so now when I go high I get high, low, and fogs. Also upgraded the fog light bulbs to the 9005. Problem is when I go back to low beams it's dark :D
-Scott
I think that low beams with fog lights on is plenty good most of the time. It is illegal in most states, but rarely enforced to drive with fog light on when there is no fog.
You can also modify the switch to include a detent position that accomplishes the same. Was a post on this BOM awhile ago. Does not burn out the wiring as the computer takes the signal from the switch to turn the brites on, whereas the older trucks ran the circuit through the switch.
