Well, maybe, maybe not. I'm a fairly good sized guy, and I don't have too much trouble crawling around under it. As I said, I have changed the transfer case lube, added the pusher pump that can barely be seen in one of the above pictures, changed out the rear seal in the transfer case about 3 months ago which entailed removing the rear driveshaft, and every few weeks, I crawl around under the truck just looking for leaks, rust, broken things and anything else that doesn't look right.
