Greetings my good Diesel buddies -
I need your opinions on my oil analysis results. Short version -
Sample 1 - 13869 miles on sample - copper 8
Sample 2 - 23542 miles on sample - copper 678
Sample 3 - 9569 miles on sample - copper 95 (oil and filters changed after #2)
All other readings are within normal parameters on all 3 samples. A tech from "oil analysis inc" called me after sample 2 and said the copper may be "leaching" from the engine oil cooler. I can't find an oil cooler on the truck, and the build sheet doesn't say anything about one. I changed the oil (Amsoil 5w-30 HDD) and both filters (full flow SDF 26 / bypass BE 100) after sample 2 and decided to sample sooner for #3. I thought maybe the reading was a fluke, but sample 3 shows abnormally high copper with only 9569 miles on oil and filters. I spoke with a tech from oil analyzers today - he said they analyze many dodge/cummins units and high copper readings are common. He did state they have never seen a failure because of this, so he could only guess as to the cause. His suggestion was for me to post on TDR and see if any of you have had a similar experience. Any ideas . . . ?
Thanks -
DStarkey
Thanks -
DStarkey
