I could use a little diagnostic help here. Just to check I'm maybe heading in the right direction...
My issue is high EGT's. At idle things are fine but once running EGT's are constantly quite a bit higher than I would consider normal. Cruising down the road, flat terrain, no load, and I can be at 1300 degrees. Not right. It's also gotten worse over a short time frame. The EGT's didn't just jump to where they are now. I noticed them climbing over time.
So first, the truck. It's a 2008 C&C, auto trans, with a bit over 400,000 miles on it. The truck is completely stock. No tuner, never had one. It starts and runs fine with no smoke. The DPF was replaced around the 380,000 mile area and the truck performs its active regens just fine. I've had an Edge Insight in the truck since new and can
monitor regens with it. The truck feels a little down on power but as I mentioned it runs fine. Due to this issue I haven't been driving the truck much but it doesn't seem to be growing oil, and the oil looks and smells normal.
So far I've removed and cleaned both MAF sensors with no change. I removed the EGR valve and intake horn both of which were pretty clean but I soaked and cleaned
them anyhow. I haven't pressurized the intake system to check for leaks but my boost pressure will hit the high 20psi area and I don't hear any whistling. A visual check doesn't find any issues. The air filter is fine but just to check I ran without it and no change.
I had the dealer check for codes and nothing was found.
Considering how well the truck starts and runs I'm not thinking I have an injector issue. However, they are original to the truck. Lotta miles for injectors, but it's not unheard of. I'm thinking maybe an exhaust obstruction but since the regens are running as normal I'm thinking the cat could be the issue. It's original to the truck. My understanding is that it's the one located in the down pipe correct? Can they clog as with a gasoline system? I'm thinking my next moves will be a more thorough leak check of the intake and then a cat
bypass pipe. What do you all think? Have I missed an obvious thing to check, do you think I'm on the right track?
Thanks for your time, help, and any insight!
