Hello everyone. I'm just wondering if I have low turbo boost pressure compared to others? I have a stock HX35 turbo with the boost elbow plugged. The highest boost pressure I have ever seen is approx 25-27 psi. (OD off, 7% grade hill pulling camper). Is this normal or do I have a boost leak or some other problem? I've owned the truck since 2003, 50K and the truck has always run well. I'd like to have a bit more usable power before getting into high EGTs. When pulling my camper many times before cresting a hill the EGTs will get too high and I have to take the OD off (thus slowing down and the engine rpm racing). I have lots of power available, just not usable power before the high EGTs. Any thoughts as to how I can solve this? Thanks in advance for any replies.
1997 2500 4x4 12 valve Cummins, auto, X-cab long box, fuel plate removed, full-forward AFC housing, ground end of rack, replaced cupped washer with a flat washer, 4K springs, turbo wastegate elbow plugged, Goerend TC & VB upgrade, Dipricol gauges (exhaust, trans, boost) 230K, KDP repaired.
