I have an 06 Mega Cab SRW. Having trouble with high EGTs when traveling 60 pulling rolling hills and 15000lbs loads. Higher speeds are better. It's an auto with 3. 73 gears using tow mode and sometime od off, doesn't seem to matter, I can reach 1350 often and easy. It has the edge with attitude and a k&n filter, but stock exhaust. I usually pull in level 1, but I've tried 2 and stock and it doesn't seem to help. Has 50000 miles on the truck. Is the cat causing problems or what should I look at doing first. [/B]
