Hopefully you guys can help me. I bought a 98 12v with 120,000 miles, stock other than a fuel plate. Well I changed all the fluids, tabbed the dowel pin, and changed leaking seals. Installed a Westach egt/boost gauge and it ran between 800-900 empty and would climb to 1500 going up an onramp full throttle. Then I noticed it had a coolant leak near #6. I changed the head gasket and it leaked again, then I noticed the crack in the head. I bought a new head, had it installed by a diesel pro who also timed it and installed BD RV injectors (mild ones). After all this egt's are still hot. Then I had a original fuel plate installed which seriously decreased power. Max boost is around 25. Now I have a total dog, with poor boost & low power. I've looked at the intercooler boots and none are torn/abraided. I don't no where to turn. I'm looking for a dependable truck with some power to pull loads between 8000-12000 pounds. I would appreciate any suggestions. Thanks, Anthony.
98 12v QC, 4x4, NV4500, 4:10 gear ratio
