See truck bio below. I haul a 1500lb camper through the Sierras on a regular basis and I just can't seem to keep the temps down. I am at a steady 1100deg at 60mph in 5th gear over the passes with tons of throttle available and no guts to push the temp gauge any further for a long period of time. Shifting down to 4th helps a bit but the truck tops out at about the same speed in that gear. Basically, my power limitations now are temp related, not Dodge/Cummins design engineer related, like when it was stock.
What I'm thinking is more air. I'm just not moving enough at WOT with the little 14cm/Piers HX35. You can also feel the engine wanting more air at high speed with no load on flat ground, around 95mph (did I say that out loud?). I know the 370's make alot of heat, but I have the 180hp fuel pump with stock delivery valves. A wiser man than I tried to convince me to put the Piers HX40 in with the 370's, but I didn't listen.
If I were to get a set of the 191 del valves (the truck runs well on the stock ones, unlike what some have said about the 160 pump and how it runs with 370's), what do you guys think about that big ole' BD bomber turbo? I'm looking for about 400hp, but mostly, I'd like to cruise the mountains and not be on the edge of the turbo temp envelope with all that wasted reserve power under my foot waiting to get out!
