Engine/Transmission (1994 - 1998) High EGT's
Engine/Transmission (1998.5 - 2002) nv 5600 problem
Truck specs:
'98 180hp 12 Valve, auto trans
-4kgsk
-#104 fuel plate
-DTT trans
-Banks Brake
The truck chassis dyno'ed at 355hp/783ft-lb before the DTT install.
Currently the boost peaks at about 22-23 psi.
The truck tows great, the power and transmission are wonderful! But, when towing a 7000-7500 lb trailer and carrying a ~1500lb camper, EGTs climb extremely fast on the PRE-turbo pyro forcing me to back out of it and I try to limit the temps to 1200 degrees.
I assume the best upgrade to reduce the EGT's is a turbo upgrade. However I have a Banks exhaust brake and I need a turbo the allows me to reuse the brake.
I was looking at the S300, but I think that won't allow me to keep the brake. What are my other options?
My truck does not smoke after the boost begins to build, do you still think it needs more boost? So how do I up the boost? A boost elbow?
Something like this? PDR Diesel Performance: Turbo Boost Control Elbow
For $35 please tell me this is more than a simple brass barbed fitting.
I've got a stage 4 hybrid with a 14cm gated housing here at the house
Is that the turbo you're suggesting? Would my exhaust brake mount to that exhaust housing? You'll have to excuse me, I don't know what dimensions the stock turbo is. I've heard it's a 12cm waste gated exhaust housing, and I don't recall the compressor housing size.
Looking at PDR's, the s300 is offered in a 12 or 14cm, and 62, 64, and 66mm. I'm still not sure my brake will mount to it, but if it did I don't know which option would be best. I know, I will call Pier's if I consider thier turbo, but I'm looking for opinions.
