Originally posted by Stubbe
High Egts what is the best way to lower these?See sig for power upgrades. I can hit 1600 in a flash. Power max 3 is almost useless it gets hot so fast.
TST says very certainly that a pyro is recommended with the PMAX 3, even with STOCK INJECTORS!!! So you add stage 2 injectors, and then wonder why you have high egt?
The PMAX is FAR from useless, but you have to let is be part of a well-designed SYSTEM. Obviously, you have the fuel to make some power, now you have to bite the bullet and get some air.
By the way, fuel is cheap, air is EXPENSIVE.
First thing is to lose the stock intake. Go with a Scotty 2 from Wildcat.
Then you will need to open up the exhaust. At the fueling level you have (about the 400hp mark), you will need a full 4" system. Pick one.
The bulk of the solution you need is a new turbo. You are simply exceeded the ability of the stock turbo. The most cost-effective turbo for your situation would be the Dodgezilla 35/40 hybrid. It's a bargain at ~$650.
After that you have the PDR 40, which can handle up to 450hp or so.
After that, you have the B1 turbos-- the most expensive, but the toughest and probably "best" single turbo available for the CTD.
After that, you should be considering twin, compound turbos.
Don't take this the wrong way, but I would recommend that you do more investigation before you do more upgrades to your truck. A little reading here and/or calling the manufacturers of the products you bought would have kept the high EGT from being a surprise-- you would have known to expect it.
For now, just keep the box below setting 3 (I know it's tempting) and your EGT problems should be controlled until you can get more air for your truck!
It's good to see another North Dakotan on here. I grew up in Beulah and Bismarck. I have been to Devil's lake a lot-- great perch and walleye fishing!
Justin
