Engine/Transmission (1998.5 - 2002) High Flow Banjo's big help with fuel pressure numbers
Engine/Transmission (1994 - 1998) 3500 single wheel
Engine/Transmission (1998.5 - 2002) HELP bad oil analysis AGAIN
Tested the fuel pressure numbers today after installing the Wildcat High Flow Banjo's. They really helped the WOT pressure. All pressures are the same with the exception of the WOT which is up from 5 psi prior to the banjo's to 10 psi with the new banjo's. I'd say that was worth the time and money spent on high flow banjo's.
Prior
15 psi at idle
10 psi at cruise
5 psi at WOT
After
15 psi at idle
10-11 psi at cruise
10 psi at WOT
Good news, gotta get mine installed someday soon. I can still see 7psi at the VP44 even with a new lift pump and filter, 10 would be nice.
Ray
That looks good. How long do you keep the pedle down for wot reading? I have been keeping mine down a second or two or until the pressure stops dropping. :confused:
