Recently I noticed that my fuel pressure was really high. My SPA guage shows it bouncing around, but it's as high as 40psi. At first I thought it was the guage, but I switched my fuel pressure and my boost guauge, and got the same results.
I have an old style Fuel Preporator on the truck, along with the factory lift pump. I can run either system, but I can only run them seperately. There is a silinoid between the two that controls which inlet is open. So when the Fuel Prep. is turned on, the fuel can only flow from that inlet. When I turn the factory lift pump on, it switches the inlet so only the lift pump inlet is open.
What's interesting is that no matter which pump I run, the fuel pressure is very high. Not quite as high on the factory pump, but still over 30psi.
The high pressure has caused some hard starting lately. If I wait for it to bleed some pressure, it fires right up.
Any idea what could be causing this? Does the VP44 have an internal fuel pressure regulator for the inlet pressure? I thought it only controlled the internal rotor vein feed pressure, and the high pressure, I didn't know it even could control the inlet FP?
