I've had my airdog on for a few months and less then 3000 miles with 0 issues till yesterday. Restarted it after a 20 min break and noticed my fuel pressure gauge at 38 psi and when going down the road it shows almost 40 psi. At a stop light I thought I felt the engine stumble a couple times,on the 8 mile trip home nothing out of the ordinary other then the high pressure reading gauge. Rail pressure was normal,Smarty was turned down for winter,got home and took Smarty off. When the engine is off,the fuel pressure gauge rests at 40 psi rather then 0. I'm not sure where to start other then with a mechanical gauge to see if I'm getting a false reading. I've got to drive 10 miles to get a gauge,if the gauge is correct will I damage anything by driving with high pressure? If the gauge is correct,where do I go from here? Could a plugged filter cause this?
