Help Please . . .
OK, I have hit 6K (2005 610/325) and have some ?'s about idle . . from what I have read you should not idle for more than 5 minutes at a time. I think this is due to possible blow by (As I understand blow by it is where the rings are not expanded to the cylinder wall and fuel goes into the oil, hence lowering the lubricating capability of the oil), but not sure if that is caused by low rpm or low temp. I live in SW FL, so during the day once I am at 180 -190 and I stop to grab a snack, I will leave it running . . ? is how long is too long . . and should I consider the high idle option where you use cruise buttons to set rpm to 1500.
I know that the manual says that you should just shut it down if it is longer than 5 minutes, but isn't engine startup the greatest wear time? So if you would imagine . . start up in driveway . . go to fuel stop, fuel up/ice up/eat up, and get on the road . . 5 hours later swing in for a stop . . let engine idle to cool turbo down, go inside for a pit, come out 15 - 30 - 60 minutes later . . 190 on temp gauge . . hop in go another 4 hours let it cool down for 5 minutes and shut it down . .
So what do you'all think? shut it down, leave it at idle, or get the cruise flash?
Thanks in Advance . . .
William
William
