BK
About 3. 5 years ago I bought a new alternator from the local autozone.
Now, need another, it's getting soft, and only can charge the batteries during the day (no headlights, and better with no cabin fan blowing).
At night with around town driving, just draining the batteries unless I keep the RPM up.
Drove the truck into the driveway last night, parked it and did some trouble shooting.
Heater grid isn't hanging on.
I charged the batteries (separately, one at a time) , they each took a while to take a good charge.
Off of charge, separated still - let them sit over night, and came nicely down to open terminal voltage, 12. 6.
Each responded well to a 100amp load test, and recovered back to open terminal voltage, 12. 6 .
Just seems the Alternator has gotten soft, and is worse than ever at idle or low rpm handling the loads.
Thankfully at this point, I don't have to rush to get it back on the road.
Been cruising our forum and others. . lots of options out there, most threads a bit older, so figured might as well ask for recent experiences, or now that you've owned xyz brand for a while, how is it. .
I found on the web, and pending phone calls, narrowed it down to these few.
Any one have experience with any of these ??
Off hand I like this shop, the only one that speaks to the issue of limited capacity of the stock cable and fuse.....
http://www.maniacelectricmotors.com...m013766HO180&gclid=CPL-6pnks7oCFVOf4Aodb1EAOQ
http://www.maniacelectricmotors.com/10gupocakit.html
And then we have in no particular order...
http://www.paperformance.com/scripts/prodView.asp?idproduct=291
http://storesense1.mysuperpageshosting.com/HS13162/Detail.bok?no=848
http://www.xtremediesel.com/meangreenhighoutputalternator1339.aspx
tia
tia
