High pitch squeal from rear brakes
Check Gauge Light
HX40 time
I have a 2000 2500 dodge. The rear brakes started making a high pitch squeal at 12000 miles. Took it to dealer changed rear shoes, ie. per tsb new part number for shoes. Started squealing at 14000 miles. Has anyone had this problem or know of way to fix it? What brand of shoes, adjustment procedure, this noise is driving me CRAZY!!! HELP!! only hear it when applying brakes lightly.
Thanks, Mark Taylor
Mark,
I just traded-in my 2000 2500. I had a similar problem with the brakes. I’m not sure I can actually suggest you do what I did, but it did cure the squealing.
I got so ****** off one day that I drove to the top of a long windy road and road the brakes hard all the way down. When I got to the bottom the brakes were just about on fire, but the squeal was gone. I was desperate…couldn’t take that noise anymore. The brakes worked fine after that.
2001. 5 3500 QC 4X4 6-speed HO 3. 55 black
1998 Jeep TJ black http://www.nm4w.org/members/puffer.htm
Mine squealed for about the first 7k mi when new. Went away after I started pulling 5th wheel.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
