I've got an odd screech that seems to come from the middle of the underside of the truck. It is NOT the brakes - which have been changed twice and gone through thoroughly. Brake input makes very little change to the pitch.
The sound comes when coasting under compression or neutral, clutch in or out. It has gotten louder lately and often sounds like a loud whistle. The sound goes away immediately under the slightest throttle input. The sound is also there under the same conditions with the eng off.
Today I removed the rear drive shaft (which is a low mileage 1 pc Dodge unit) and drove it and the the noise was gone. The DS is in perfect condition and the joints are tight and buttery smooth.
Since the rear end is under the same loading conditions as when the shaft was in, I cant see it being the problem. Or can it? The rear end was gone through 16K ago. (ugly story)
Fluid levels are good and no metal is evident in the transfer case or diff.
Can a transfer case make a noise like that?
Any and all idea's are welcome!
Thanks!
Scott
Thanks!
Scott
