My Daughter has a 2006 3/4 ton. Its just out of warranty. There is a leak
at the #4 high pressure fuel line. I checked the nut that holds the fuel line
to the injector. Its tight. The bracket that supports the line was loose. Im thinking that vibration because of the loose bracket caused a crack in the fuel line. Is this a common problem.
Do you think the dealer will cover this. She is about 3000 miles over warranty. Your thoughts.
Thanks in advance.
Mike
Thanks in advance.
Mike
