Well I thought I had this problem worked out but now it is back, very frustrating to deal with . . here is the scoop.
A few months ago my water temp gauge started to fluctuate up and down while towing on grades (not heavy) After this happened I noticed my AC temperature was warm at idle. It would get colder when driving. There were no codes present to indicate a fan clutch failure, but I couldn't hear the fan kick in like it normally would at about 210 degrees. Temps got up to about 240 degrees.
Took it to the dealer, they did a resistance test and they replaced the fan clutch under warranty.
The problem returned about 12,000 miles later and the dealer fixed again (replaced fan clutch) even though I was just out of warranty.
These problems were prior to my recent installation of my TST.
Drove the truck another 10,000 miles and the problem returned. Took my truck this time into a dealer in Riverside , CA and they replaced the fan clutch AGAIN and they ALSO did a TSB reflash.
Drove the truck another 3,000 miles and bingo, here it is again. I'm thinking this is definitely something more than bad fan clutches. My temperatures are fluctuating again, my AC temp is warm at idle again, and I am ****** again.
Some things I tried -
1. I checked the coolant level, it is good and the coolant is new.
2. I relocated the ground wire from my TST to the inside dash panel. Tomeygun posted that this helps thew AC problem, it didn't.
TSB reflash
TSB reflash
