Has anyone every experienced a higher EGT reading after installing a 16cm turbo housing?
At my normal cruising speed (2100 rpm) unloaded I have about a 2-3 lbs drop in boost (was 12 lbs) and 0 degree drop in EGT (750-800 deg). If anything it seems like I gained about 50 degree. Also at WOT my boost has dropped about 5 lbs (to 42 lbs) and I can still peg 1500 degrees on my egt gauge but it just takes a bit longer. Maybe 1 or 2 seconds.
Overall the new housing doesn't do much (for me) until I'm in the higher rpm range and even then it very little.
John
John
