higher
dumb question
electrical wizards needed
:eek: :rolleyes: does any one know where i can get a 4" lift for my 90???:confused: :confused: :D I think I need it to fit 33" 8R19. 5's:D and should I get 225/70R19. 5's or 8R 19. 5's??:confused::rolleyes:
Hi F. Boyle skyjacker makes a 4" suspension lift for your truck here is skyjacker #318-388-0816 and summit racing sells skyjacker products best if you call skyjacker and get part#s before ordering hope this helps www.summitracing.com good luck with lift
f. boyle
Those tires will fit great with only a 2 1/2 in kit, when my truck was new i was running 285/75/16's with no lift without any problem, but the skyjacker springs shure makes it ride good
Rick
The 33's should fit in the stock openings if your suspension hasn't sagged. The previous owner of my 89 had 38. 5's on it with about 3" of home grown lift and the front wheel wells cut. My 33's look small now. Forgot to mention he was carrying a Boss 8' V-blade on the front with the 38's on. I'm probably going with the 305/85R16 Buckshots when I replace my tires, depends what we end up with for a tire franchise at the shop.
If you want the lift, check out Rocky Mountain Suspension at rockymountainsusp.com . They had the most reasonable prices when I was looking for lift for my 79. Make sure to tell them you have the deisel as the kits are different.
Welcome to the club, enjoy.
