Finally got my fifth wheel hooked up and pulled a nearby grade that is very steep. It is a good benchmark, because I know how well my friends with Duramax and Bombed Ford do.
I am about 1500 lbs heavier than the two of them so I have a bit of a handicap.
The bombed Ford could climb the hill at 60+, but has to back out because of EGT's. Too much fuel I suspect from his Western Diesel fueling box.
The Duramax can pull the hill at 55 MPH.
I used to pull the hill at 45 MPH with my '99 which had an Edge. Bone stock my H. O. '03 pulled the hill at 53MPH.
Considering the heavier weight of my fifth wheel I'd have to say we are all pretty evenly matched in terms of power. It was really nice to pull the hill and hold a conversation at a normal volume. My '99 would kill brain cells when it was wound out on a long pull!
I noticed that to get the power from the H. O. you need to pull more RPM's than the Gen. 2 trucks.
The six speed was really nice as no matter what hill I climbed I could find a good gear. Had to pull the big hill in fourth as I didn't have quite enough for fifth. However, I pulled the hill a second time from an on ramp right at the bottom of the hill and was able to get all the way up through fourth to 53 MPH. It had plenty of reserve in fourth.
I can see where another 50 HP or so would see me doing the hill in fifth at close to 65 MPH.
Dodge has got a winner with the stock H. O. for towing. A fuel box would be just icing on the cake!
