Hi I have read a lot of the posts about hissing under the dash around the brake pedal shaft going into the hydrabooster. But I checked the hose for the liner being dislodged and found that there was not a problem there. My 2004 Dodge 2500 Cummins just started hissing out of the blue. It only happens when you turn the steering wheel, it goes away if you push on the brake pedal or return the steering wheel to the normal straight ahead position. I am unsure as to what to check or replace now. To give a little more back ground the truck has roughly 160000 miles on it and I just bought it. I have maybe put 400 miles on it when this problem started. Any help would be greatly appreciated. Thanks in advance.
