Yep, I knew about hot bulb diesel engines. In the late 40s and early 50s there were a few in the east Texas oil fields near where we lived running walking beam type oil well pumps. They were a one cylinder very slow running engine and ran for years without stopping and would burn about any low grade petroleum fuel. I remember the operator had to hold a blow torch on the hot plug for quite a while before attempting to start it by spinning the large heavy flywheel. The engines I remembered had a manual compression release petcock on the cylinder to ease starting. Before starting the engine, the operator would open the petcock to lessen the compression and once the engine started, he would quickly close the petcock to return the engine to its full compression. The walking beam gearbox was geared down the speed further and was counterweighted to offset the lift stroke on the sucker rod that operated the piston/cylinder down inside the relatively "shallow" well.
What is amazing is the progress from the end of that film to today's modern diesel engine.
Bill
