Hitch help
Looking for feedback on RV Resort Memberships
wiring connection advice
HELP!?!?! I thought my '96 came with a beefy hitch, but turns out it is only a class 3. It does not look too healthy with my 9k lb trailer hooked to it. Please advise where to get a class 5 hitch for a reasonable price.
Thanks in advance!
Rodney
Again Ruenel!
http://www.reunel.com/
Rear bumper with receiver (15K #) was less
that $600 a year ago. It is 1/4" plat
and very very strong.
It will definitely protect your rear end.
I backed into a tree :eek: and no damage.
I had a 35' flat bed graze it and it took
off some metal which I filed and repainted.
And put a ~1" crack in the end cap weld.
He lost a lot of paint. The bumper did
not bend nor did it get into the body work
like the piece of sh#$ stock one that it
replaced.
IMO the Reunel 15k rating is a bit mis-leading. The bumper itself was tested/rated for 15k - that DOES NOT mean the mounts on your trucks frame are rated/capable of 15k. Same problem with the Class IV/V receivers - sort of. At least the receivers from Drawtite/Reese/etc distrubite the load over a larger area of the frame compared to the Reunel bumper. I really like the looks of the Reunel bumper but I'm not willing to give up my independently frame mounted receiver hitch.
Brian
Correct! Bumper rated over Frame
You are correct the Ruenel bumper is
rated over that of the frame for the RAM.
If you put it on a larger truck, say or
2 Ton or 5 Ton then you could use it at
rating with a Pinta but not with the
receiver.
My thought was, I know I will
occasionally load it heavy and with out
getting on a truck scale I won't know that
it is over loaded. So, I wanted a little
extra margin built in.
Also, it was less than the OEM bumper that
got hit and the insurance was going to replace
anyway. I realize that this is probably not
the case here.
Thanks in advance!
Rodney
Do a search on the Putnam Class V XDR then call 1-800-932-8373.
I think you will like the price plus free shipping to Vermont. Small company, not sure if they have weekend hours. 2" reciever by the way.
