Hmoemade CP3 Dual feed line, anyone got pictures of one installed? Any power increase
610 cyl head on 03 HO??
FASS Installation - 2004
I was wandering what all comes in the dual feed line kit. it appears to be just a fuel line and two fittings. Is this correct? Why could you just make your own. $300 for a fuel line and two fittings is a little much. Is there somthing I'm missing. Is there any increase in power nitced with the dual feed line?
I looked all over the place to get a fuel line for my Dual CP3 system that I am building. I bought the line from II. It is one thick line. Hard to get it made.
Malcolm
Where can you find a flexible line that will hold 30,000 psi?I didnt think it was possible,but I would buy one if I could find it.
Would anyone know a shop I could call,give them the dimensions and fitting sizes,and have them make a line. I seen the parker website,but who can I buy the completed line from?
find a hydraulic shop that will make a line good for +30,000psig. . pretty tough. .
hahahaha I had a leaking power steering line fixed at a hydraulic shop all the had to do was tack weld the aluminum where the line had wore through. no their aluminum welder was out fishing so the cutmy line in 2 then added some fittings and hose in between. this started the age of the power steering nitemare. 3 advance autoparts power stering pumps, lots of fluid, time, 20 minutes of bleeding procedures per pump install (sorry I am picky with my own stuff) and finally a mopar pump took away all my problems. SO what I am saying is if you have common sense you might be better off building the fuel line yourself. It may cost you money to properly equipt yourself with the tools but hey if it works for you and you show some dyno sheets before and after with a typical modification list of the basic neccessities of the guy here on TDR and just show how much power increase then start making them and selling them on tdr.
