Details here: TDR Privileges
Can anyone give me directions on adjusting a Hob pressure switch?
The application is an ATS Torque Pro 2000 propane injection. ATS personel indicate that it is not user serviceable, but the literature they provide says it is.
if it is an actual hobbs brand switch, you can pull the rubber plug out of the back end and turn the screw inside to adjust the pressure it trips at [tighten higher, loosen lower] #ad
