Hoesli catch can install
What happens when Dodge goes cheap on a flex plate
What service does my 06 3500 need?
OK, need some help. 05, 3500, DRW, NV5600, 5.9... I bought the Hoesli Diesel catch can and valve cover. How is it installed? Catch can has 3 hoses, 2 from valve cover, 1 for the drain/crankcase return. Are the valve cover vents/hoses, just open to the inside of cover? or do they need to be connected to something? With that, I am assuming the crankcase filter can be removed??? The hoses on the cover are attached to the rear side of the cover I am aware that the drain of the can will connect to crankcase return.
Please explain the rest of this install, I haven't found any posts on the connections, here or elsewhere.
Thanks much Ricky
Tramplineman, Thanks, I had to look at that link a couple extra times...it looks as though the drain line goes back to the valve cover, but I see that what I assume is the other vent line that goes to the crank case vent is there also. I thank you much, for the link, I will now guess that that other vent line goes to the valve cover. (AKA the CCV in line.) Again Thanks much.
Ya, it appears the two ½” lines run from the valve cover to the top of the filter canister and the ⅜” runs from the valve cover and T’s into the ⅜” drain off the bottom of the canister to the block.
