I read, with interest, what Sojourner had to say about the difficulty protecting & patching EPDM roofing systems. I'm, also, curious about what his opinion of the system I've tried, is.
In January, '01, at the Quartzite, AZ. RV Show, I ran across a product designed to protect & patch EPDM & other roofing materials. It's called Rapid Roof III. It's an Acrylic Elastomeric Roof Coating. It looks like white glue (Elmer's) & applys with a paint brush or roller. For areas needing extra strength, they have a thin, very strong & easily pliable, polyester meshwork called "Spunflex". Rapid Roof III is made by Conklin Co. in Shakopee, MN.
At Quartzite, the company explaining & selling this product is Minnesota Roofing & RV Specialties. They have been in business since 1988 and after trying numerous products, found Rapid Roof III to work the best.
Basically, you scrub the roof with detergent & a 3M scrubbing pad to get the "chalking" off & rinse well & dry. Then, you start painting The RR III on . In areas that need extra strength, You put a coat of RRIII on in small areas & while the RRIII is still wet, you lay the Spunflex on top of the wet coat of RRIII. You 'pat' the Spunflex into the RR III & then apply another coat. The product dries to the consistency of rubber, in a few hours. Spunflex does to RR III what rebar does to concrete.
If you had a tear in the EPDM that has a "flap", you can paint underneath the flap, lay the flap into the wet RR III then paint over the flap, lay the Spunflex into the wet RR III, pat it down into the RR III & apply a second coat to the wet first coat. Let it dry & you should have a tough patch.
My trailer sits outside in the desert sun (Phoenix, AZ. ), year around & my roof still looks great. If you stick your fingernail into the RR III, it's still pliable & rubbery. No sign of drying or brittleness, at all. It's supposed to last 10 years, or more. The local distributor for RR III has had it on a cube van for many years, now, & when I looked at his roof, it was still rubbery & pliable.
I used to worry about leaks, quite a bit, since I had to replace parts of the the wooden framework on an older trailer, twice. It was expensive & a pain in the neck. Since I installed the RR III, I don't worry, anymore.
This stuff is pliable enough that I even put it on my vinyl awning cover. It was just beginning to start to deteriorate from the sunlight. I painted about 12-14" or the outer roll that is always exposed to the elements. It's flexable enough to do this & still looks good. Should extend the life of the awning by quite a bit.
I know this is sounding more like an "infommercial" but, this stuff is working GREAT for, both me & a couple of my friends. Remember, we live in Phoenix. About as harsh of a climate as an EPDM roof can experience.
If anyone is interested, Minnesota Roofing & RV Spec. has a website (
www.rvroofmn.com).
I know if I had a tear or hole in my rubber roof, RR III & Spunflex is what I'd use to repair it.
Joe F. (Buffalo)
