Engine/Transmission (1994 - 1998) hole in t-stat
2nd Gen Non-Engine/Transmission Towing performance
Engine/Transmission (1998.5 - 2002) help on wiring hobbs?
heres where i put mine on the "updated" cummins unit, just make sure you don't drill into the wax element that's the next thing inside of the piece i drilled though
no jiggler on the new style t-stat that i got in a cummins box from the dodge store, it's not for bleeding air like they usually are needed for as theres a small pipe that takes care of that, i did it to get the temp to stabilize, my truck didn't have a thermostat in it when i got it and when i installed one it got the gauge to flapping which most consider normal, i don't like that so i went after what i thought was the cause, the element is too isolated when it's closed where they put the t-stat and it overreacts, this sets up a cycle that had mine bouncing from about 220 to 160 every couple minutes, now it runs about in the middle towing or empty
HEMI®Dart said:
Why the hole? The older versions had the "jiggle pins" that they did away with.
Interesting. The New revised Cummins T-Stat is supposed not to "Cycle". This is the one I run. Mine does not cycle. Although, it seems to warm up slower and run a bit cooler. Most noticeable in the winter.
p/n 3934373
EDIT:
WDixon27,
The revised T-Stat still cycled for you?
