Loren
Okay. I admit it. I have ALMOST too many accessories. Many of these require one or two wires from the engine compartment into a control box in the cab. I have pretty much used up all the space available in the original factory holes with the original factory grommets.
I now need to cut (with a hole saw), or drill, a second hole into the cab for wires. I would prefer a hole that's about one inch or so in diameter so I won't have to go through this again. The hole can be through the firewall from the engine compartment, or through the floor from the chassis area beneath the truck.
The truck that needs the hole is the 2000 model listed in my signature, but I would expect that the same procedure would also work for the 1995. My newer truck has the four-wheel, anti-lock brakes, so I can't go through the firewall near the master cylinder. That space is all used up. It also has the six-speed transmission, but there seems to be a reasonable amount of room around the transmission. That may be a possibility.
I will install some sort of grommet (suggestions are welcome) to seal the hole somewhat and to protect the wires. I will also run them through a piece of split plastic wire loom.
It would be nice if the wires enter the cab in a convenient, but invisible location, like under the floor carpet along an edge, or up behind the instrument panel.
Does anyone have any experience and/or suggestions on where and how to make this hole?
Loren
Loren
