Archived Holiday trouble...
Archived Help, only have reverse,Neutral and Drive.
Archived no OD and converter wont unlock
He has no turn signals, no emergency flashers and no brake lights.
The fusses appear to be ok
From a friend who has a 99 CTD. Naturally this happens on a holiday.
Any suggestions appreciated!! TIA
I ran into a similar problem on a first get that turned out to be a fusable link at the battery. You know, where a big wire (about 10 ga. ) necks down right before attaching to the battery. Worth taking a look.
-Scott
Fuses #4 and #5, both 20A, in the PDC supply juice for these circuits. Does the CHMSL (3rd brake light) light when the brakes are applied? If those fuses check out OK, and the CHMSL lights up, it's probably a bad multi-function switch (in the steering column - steering wheel needs to be removed to change).
It's also possible the hazard switch is stuck - won't hurt to fiddle with that a bit, before ripping the steering column apart.
Here is the response from him after he read your suggestions:
"We are in business
Opened up the power distribution box and there were 2 fuses bad.
20 Amp Hazard/Turn
20 Amp Stop Lamp
Thanks a bunch
Jim"
You guys are great!!
