i just did a little bit of info searching and on the holley site i discovered that the summit catolog is misleading as to the output of this pump , yes it is rated at 140gph and 14psi ... FREE FLOWING , under pressureied use it only flows 120gph ... AT 9 PSI ... this explains why those that have switched to them have not seen any huge increase in system pressure .
