Engine/Transmission (1998.5 - 2002) Holley HP 150
Engine/Transmission (1994 - 1998) mystery switch mystery
2nd Gen Non-Engine/Transmission POS HELP door pin and bushings
Has anyone tried the new Holley HP 150 as a lift pump ?
It looks like it has the right specs, Gerotor pump,150gph,
17psi with an internal pressure relief valve.
Or the HP 125 as a pusher pump ?
125 gph, 7psi.
I have used the aeromotive SS 150 pump part#11203 works good idles at 21psi wot 15psi. with Mach 6s and edge drag box on 5x5.
