Holset Hx35/40 hybrid
Intercooler boots 2nd gen
1996 Dodge Dually bed (new takeoff)
The Turbo is Off the market for the time being.
This is the old turbo off my truck. I didn't buy it, it was on the truck when I got it. It is gated at 30psi, ran well, appears all Holset, cast Holset on both turbine and compressor side. I will be honest about its condition and it should serve you well. However, understand that it is USED parts and sold as such. I don't take returns. I have the angle attachment for the back of the turbine housing as well to join up with the down pipe (see last picture). I can include a downpipe and V clamp as well for an additional fee, it fit up with my 5" exhaust. Shipping on that downpipe will need estimated.
The turbo has no shaft play that I can feel, spins freely, and wasn't leaking around the seals when I had it. It does have some miles on it and has been warm, probably 1500+ peaks a few times and cruise at 1100 ish. Not a lot of original paint left on it, and it has been run for probably 40-60k miles or so if I were to guess. It was also run with an AFE oiled filter and has the black oil on the vanes and inlet from the AFE filter oil. I tried cleaning it off, but it would take more effort than i have had time for thus far.
Asking 800, shipped in the lower 48.
Has it been Modified to be a 35/40 hybrid ? Reason I ask is that look's to be same turbo that I have off of a Stock second gen truck .
Industrial Injection among other make or have made the turbo. You can search for it. The benefit is that it is pretty much bolt on due to the similar housings.
