holset intercooler with banks changing color
installing valve body
i've spent the last two days towing a 22 foot boat (about 5 ton) from florida to connecticut. when i left florida, my intercooler was the stock silver color. about half way home, the cooler started to turn gold on the outside and lower intercooler tube. i took off the intake tube and the inside of the cooler looks ok. i have a banks powerpack and psychotty air. i was running about seventy mph at 2600 rpm with about 30 psi of boost. can anyone give me some advise on this? thanks.
1999 RED LOADED 3500 QC DUALLY. CAP,331N. DUNLOPS,ALPINE AUDIO,PSYCHOTTY AIR WITH K&N,BANKS POWERPACK,AND JENETTY 4IN. EXHAUST... . STAND BACK!!!
Hey Ram,
You are right across the river from me. #ad
I'll bet its just the hot compressed air coming out of the turbo that turned your intercooler piping a different color. If you were in a hot climate and had lots of boost, the compressed air from the turbo can be in the 200/220º temperature range before it gets to the intercooler.
2 members here, drawson & illfem used an infared thermometer to check intercooler inlet temps after a run. Their readings were 210º & 200º.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 03-17-2001). ]
HEMI:
lets get together and talk seeing we are so close! its good to know there is another tdr member so close! i'm trying to get a local chapter together in our area. send me an e-mail with your land line and i'll get in touch. my names james. e-mail:NEWT3437@AOL. COM. talk to ya soon.
https://www.turbodieselregister.com/ubb//Forum9/HTML/000205.html Or something like that.
Y2K+1 <font color=white>3500 4X4 Quad Cab</font> Powerpacked , Jakit's Front End Leveling Kit with 255/85R16 BFG M/T's Custom Rhino Liner (as seen on website under tool man's truck feature) DeeZee Goodies, Hadley air systems 150 psi comp and air storage.
Keeping the rubber side down 'n' shiny side up Will Bring a smile at the end of each day (hopefully) See Her Here #ad
[This message has been edited by ToolManTimTaylor1 (edited 03-17-2001). ]
