Holy Intake Air Flow Batman!
Sudden Loss of Power???
Back-Up Lights Have Quit!
The other night I was playing on my truck...
I replaced the air filter with an Amsoil unit about 14 months ago. Still pulled the filter minder down about halfway. #ad
After the recent trans improvements I could pull it down about 2/3 of the way. After reading the recent air filter debates (K&N) I noticed somebody mentioned an improvement if the air duct into the fender was removed.
THEY'RE RIGHT! #ad
I highly recomend it! Can't budge the filter minder now. A bit more turbo noise too. That alone might make it worthwhile for some.
Yes, it is a bit of a PITA job but...
Remove the top of the air box and filter. Best if you undo the clamp at the turbo inlet and remove it as a unit.
Remove the funky plastic nuts holding the air box base down. This best accomplished by lightly clamping a needle nose vicegrip on to them and pulling up on them as you unscrew them.
Remove the box. Remove the duct.
Reinstall the airbox. You need to pull up on the nuts as you tighten them. This is the hard part.
Install the filter and lid. Don't forget to tighten the clamp to the turbo inlet.
Let 'er rip! #ad
I am curious to see the difference in filter minder reaction with a stock (paper) filter after removing the duct. I don't have one so I can't provide feedback...
'94 3500 4x4, 205,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Air Filter & Lubes, AWOL silencer ring & intake boot. NRA member. Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
I been thinking about doing it to mine but haven't had the time. It looks to be a rather easy job. I still use paper filter, but I need to check filter minder out. My last filter was covered by oil(probably oil burner in front of me)some how(oil only on bottom cleats).
Mechanic put new filter in about 2 weeks ago during regular servicing. Minder hadn't budged(filter been in about year)I wasn't to happy about him changing it but the with new filter I hear the whine better (it was getting a little quiet).
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
