Our DirecTv setup is giving us issues, installer says it is an AC power issue in the house (open ground or polarity reversed I believe he mentioned). I checked most all outlets, each comes up very similar Neutral > Hot = 122. 1, Ground > Hot = 122. 7. I checked all of the outlets on the (livingroom) circuit involved; neutral, ground and hot are all where they should be. I also checked using an outlet tester and every outlet tests Okay... ? Is it normal for a slightly different voltage when measured between ground and neutral?
JJ
JJ
