I just bought a homebuilt something -or -other that has a 17HP twin briggs, a 4 speed step transmission and a front end that has no gear reduction--that is one quarter turn is rack-to rack on the steering. The present front wheels are 6 inch to make it possible to steer I am thinking that a small hand winch can be used to multiply the turns of the wheel for steering. Steering u-joints might be as simple as u-joints from a 3/4 drive socket set. Hopefully this would enable me to add larger front wheels
I want to make a low-speed ATV with max speed of ten-to 15 MPH. Part of this will be accomplished with bigger tires and part with final drive pulley on the belt drive. Prresent suspension is solid front and rear with no springs. The suspension that I have considered is 1. No changes--just add big tires with low air pressure. 2. add pivot to front so the front wheels can twist when dropping into a hole[garden tractor suspension like a wheel horse]3. Also add a suspension seat with springs and shock that floats over the sub- frame.
I feel that this is about my level of understanding and skill. I am enough of a realist that adding a really complex independent suspension would eat enough of my time that a second job at a low wage would be cheaper that trying to build a coimplicated suspension system. This machine 's purpose is to get back in 3 miles or so in the South Dakota gumbo that adds 5 pounds of mud on your shoes if you try to walk in after a rain. I need to keep the frame higher than a go-kart so the transmission will not get muddied up.
If you can stop laughing at these ideas long enough to offer advice ,let me know your thoughts
