2nd Gen Non-Engine/Transmission Homemade Boost Fooler?
Engine/Transmission (1998.5 - 2002) No Brakes NO Steering
Engine/Transmission (1998.5 - 2002) 98 motor on EBAY with only
Alrighty - whos got the good ol-timey homemade boost fooler circuit diagram. I've got a Superchips tuner on my truck, but apparently with the wastegate blocked its still more boost than the truck wants to see - So it sets a P0234 code.
Thanks in advance
Jake
Couldn't you install a mechanical bleed valve running to the MAP sensor? Sure, it's not graceful, but could work... some gasser dudes/dudettes do this.
Here's a link for a simple voltage clamp that you could install that will prevent the ECM from 'seeing' the additional boost in the form of increased voltage from the MAP sensor. For $86, it isn't a bad deal... but existing stuff specifically made for ISB's is a 'bolt-in' process.
Matt
