We've built all our own tanks... we have a metal shop shear the steel for us out of 14 gauge MS and we wire feed weld them... once they are made before the filler cap is cut and installed we install the line to the fuel pump we install on the frame... 120 gal bed high tank is about $120 worth of metal. . we weld all edges, too costly to form...
The bottom plate is on a slant so that when the tank is empty its got less than 2 gals in it. . and we run the output through the cab side of the tank out the plastic plug in the front of the bed...
We use an air pressure regulator set to 2 psi and inflate the tank and repair all leaks... we than cut in the fill spout and later wash and paint the tanks with bed liner... Husky Liner as I remember...
We've done this now for a lot years with each new truck... must be 8-10 by now. .
I've never used a tank liner kit. . but we do run the fuel from the tank, through a 10 micron filter, through a 1/2 lb back check valve to an electric fuel pump into the vent kit we've installed on the factory tank...
We through a dash switch and watch the fuel gauge go up... at 3/4 full we stop... when this process slows, we know the filter is plugged and replace it...
All our trucks have the DOT # on the side, and tow, so we have been inspected more times than I can count and have never had a problem but have had the tanks dipped for red fuel at least 2-3 times a year... .
Oh yea, one officer thought we might be hauling drugs, even though you could see to the bottom of the tank with a flashlight and measure it... . he had a drug dog come down and sniff the truck... we waited 45 min for that... . all the time we laughed at the thought. .
I've got an extra out of a 05 we put a flat bed on... $130 you haul... its about 125 gal. .
