I have had my Honda 3000 for about eight years. I have never had a bit of trouble with it until this weekend. We dry camped last weekend running the AC a good bit. My 15K Carrier V usually keeps it turning half throttle or a little better after starting. I had no problems at all last weekend.
I hooked up Friday and started the gen to air up my bags. It skipped a few seconds, leveled off and ran fine off and on about six more hours Friday with no AC needed so mainly idling.
Saturday morning I started it and it died as I pushed the choke in slowly. When I tried to start it again I got the "stuck valve" symptoms.
We removed the valve cover and found the intake stuck open. After treating it to some WD 40 and some twisting and the push and pull it started and ran fine. We did the normal service due soon, replaced the plug which looked good, adjusted the valves etc. It started great and ran fine for 15 or so more hours Saturday and today.
I normally run on Econo but the gen has been worked pretty hard weekends since Labor Day running the AC etc.
Has anyone else had a problem with stuck valves? I have had the problem before on Briggs engines which weren't run regularly, but never a Honda. I started adding Marvel Mystery oil to the gas after the stuck valve and did the same on my Briggs engines. Any known problem with adding Marvel Mystery oil to the Honda's gas?
Thanks.
Thanks.
