I just rebuilt an '87 Honda Civic 1500 (carburated 12 valve with aux. valves) but I need the correct timing procedure. The car was driven by my dad for some time after my uncle had the head rebuilt because of a broken timing belt and gave the car to my dad after fixing. I found right away that the cam was off a tooth so I fixed that and timed it but at the time was confused due to no hood sticker and a lame haynes manual. Well it finally burned two exhaust valves real bad (#3 and 4) so it got parked for over a year. Before my uncle got it it was a 5 mile/day car so that killed the rings. The oil rings were stuck and it would go through oil like gas. It has only 117k on it now. When I gave up and left the timing last time I set it to the center mark with the vacuum hooked up, which must have left it retarded. This put the dist. near the center of its adjustment.
I need something cheap to drive so I finally tore it down and did a ring/bearing job and had the head fixed this week. Now I'm back to the same place I was long ago. If I time it to the center mark with the vacuum unhooked like the book says it puts the dist. almost clear to the advance side, which doesn't seem right. Also when vac. is hooked up it puts the timing at about 41 deg, which seems way extreme. This one has a dual diaphragm advance. The main hose goes straight to a vacuum manifold so full vacuum at idle. I have not traced the other one yet but I have never felt it doing anything.
My question is am I just doing this wrong or is this other hose supposed to be countering what the main one is doing and retarding it some? Anyone have one of these cars or a book that would give the proper procedure?
I haven't driven it yet (no insurance/license) but if I remember right it didn't run right set this advanced years ago when I worked on it.
Thanks,
Mark
Thanks,
Mark
