Howdy all,
Well, I began my inevitable slide down the path of BOMBaholism last night. My K&N RE-0880 and the 25-0880 pre-filter arrived from Summitt Racing, and they went in after work. Man, you sure can hear that turbo spool up now! When I go up hills and get past about 10 #'s boost, it sounds like the turbo is gonna suck the filter into the impeller blades.
Since this is my first K&N, I'm hoping I oiled it up properly. I follwed the directions on the charging kit, and sprayed the entire filter surface twice, about 15 minutes apart, then installed it. Does this sound sufficient to you, or should I maybe give it one more spray of oil this weekend just to be safe?
Next item up for bids is a new 4" exhaust. How soon it goes in depends on how much mr IRS wants me to send him next month..... Then hopefully DD III injectors will soon follow that
Tom
Get outta the way: The Cummins is Cummin'!
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, TDR decal, Jack antenna ball
2001 Zinc Yellow SVT Mustang Cobra on order
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
Tom
Tom Golden
