Engine/Transmission (1998.5 - 2002) hooking up tee on fass conneter
Engine/Transmission (1998.5 - 2002) My Turn- Clutch
Engine/Transmission (1994 - 1998) Bad Mileage
You should be able to add a tee anywhere in the line if you used the hose supplied with the FASS unit. I put a tee inline just past the factory fuel line. I used the factory line as its the same size as the line FASS supplied. I used their blue hose to plumb to factory metal line and I use a electrical pressure gauge sending unit plumbed into the tee. :D
