Horn stuck on, following a county sheriff, got some dirty looks.
In reviewing all the posts, it is likely the "horn pad' which is the vinyl cover in the center of the steering wheel in which the horn buttons reside. There may be a horn relay somewhere, but not according to my shop manual and even the Dodge parts guy couldnt find one. Maybe there is one integrated into one of the power modules, I found some reference to that in other posts but it is fuzzy.
My shop manual gives little details, but after disconnecting the batteries for 1/2 hour, just two bolts behind the wheel and it the entire airbag assembly came off. there are four steel tabs on top and bottom and two on the side of the cover that do not appear to be bendable.
How do i pull off the old cover? Dont want to cut into it because you can see the airbag right beneath it. Maybe pull it apart at the center where it would split apart in an accident?
would appreciate a tip.
