You will need more air. A better air filter would be a start. Talk to Keith at Diesel Dynamics. You will probably need to upgrade the tubocharger.Double J said:You should be real close. It should also be real toasty with the stock turbo, keep an eye on her.
EGaskamp said:I just ordered a Drag Comp and am going to order the dd3's tomorrow. Do yall think that 400+ hp is reachable with this setup? I did the numbers in my head and the drag comp (120hp) and the dd3's (100hp) equal 455hp. Is this around the range I will be? Thanks
Eric
